Radiator bolts.....
26 Aug 2009
Right, I'll keep it simple. I need bolts for the following radiators, all using standard 120mmx25mm fans:
1. GT Stealth 120mm rad: Box says M4 threaded holes.
2. Unbranded 240mm rad: Look exactly the same as GT rad, so I assume M4
3. Unbranded 240mm (Thick) rad, holes are smaller, I assume M3
Any help finding the correct bolts is very much appreciated :D
5mm for the rad worked fine for me with an EK rad that looks almost identical. Although wouldn't be able to say 100% whether that will be OK.
