- 11 Jun 2021
- UK
Hey all,
Need help. Got myself some 360mm radiators for my build that I was planning to paint white, but I can’t get them past the cleaning stage. They’re about 8 - 9 months old, been sitting dry for about 2 months. I’ve tried using deionised water (about 10 litres so far), tried using vinegar solution (only during the first few flushes), and also tried using coke! (For the phosphoric acid) and 30+ drains since and it is still not coming out clear, small little green bits and sometimes dark flakes of metal. Loosing hope here, should I bin them and get new ones, or will mayhem blitz save them?
I've already bought an inline filter so I'm going to try the above suggestion by running a short loop. Not gonna order the mayhem kit for now until I lose hope with the loop not doing anything either. Really don't wanna waste these rads as they're about 70 quid new
