I'm new to watercooling, but come from an engineering background.
The information that i'm after is the following.
There is an elementary equation from basic thermodynamics that states that the rate of heat transfer (Q) equals the mass flow rate (M) times a Constant (the specific heat of water) times the Delta T (fluid temp out minus fluid temp in):
Q = M x C x Delta T
The problem that i have, i cant find any info on the radiators to work out the heat transfer to get the temp change in the water. I should be able to work out the temp in (as i'm aware of the amount of wattage mu cpu is using.
Can anyone point me in the right direction to find information on radiator cooling information?
As i want to calculate the correct size rad.
Q = M x C x Delta T
