Hi there,
Currently I have all my components running under water (gfx/cpu/mobo). I am running two loops but it's running very hot atm.
I am using cheap fans and radiators atm an i think i have rubbish air flow in my case. I want to move everything to the Lanboy air case..
Questions I have...
Can I fit a 360 rad in the top of a lanboy air?
Can you suggest a very good 240mm radiator?
Currently i have the cheap EK CoolStream Radiator XT 240 rad and the stealth black Ice 360. If I got two better(suggestions?) 240 rads to replace these too, would this improvecooling?
Can you guys list some very good 120mm fans? I want to cut down how many fans I have atm.... and just use very good ones instead.
thanks for any advice.
Questions I have...
