Starting to get a few bits gathered together for a watercooling loop, going to mount a 120.3 rad in the roof of a Lian Li a70f case, (when i can source a replacement top panel), wondering about fan setups, im thinking of using three 120mm fans shrouded with old cutout fan frames, looking for advice on good 120mm fans to use, ive been using a TRUE black air cooler for a while now (tight fin density), the fans ive used with it have been sharkoon 2000's, 3 pin and sharkoon pwm 400-1200 rpms, both have worked very well on my lapoed TRUE black with an i7 at 4ghz.
