Radiator fan
27 Jan 2009
Hello guys
I recently bought some 480 radiators (from OCUK) price was too good to miss and was wondering which fans are good for radiators. I was looking at the Corsair sp led series but was wondering what other good options there are.
Thanks
EK vardars are pretty good they match the Gentle typhoons for performance and are PWM and they dont whine like the GTs when you slow them down
the SPs are a good 3-4c worse off than the Vardars or GTs
i know this as i own Vardars, GTs and SP QE
all fans mentioned run at 1450 rpm dont know if the same applies at higher RPMs
Think about how much noise you can put up with. I have Corsair SP120 quite and if you run them at or close to full RPM, they are suprisenly loud. EK Vardars and Gentle Typhoon gets the plaudits presently for full RPM and less noise.
