- 5 Feb 2009
I have just got a Zalman 6 Channel Fan Controller, and 7 Noiseblocker XL2 fans, for use on a 480 & 360 Radiator, I am wondering what the best combination of fans per channel to use. From what I read each fan is 1.8watt so if I used the full 4 on the 480 to a single channel I will be just over 7watt would that be acceptable or should I split them into two channels?
Regards
-Ninja
Regards
-Ninja
