Radiator fitting question
28 Sep 2004
westmidlands
Get rid of the fan grill for sure. Adding the fan is a good idea, I would move the fans on the rad to the other side so they are pulling air off the rad too.
Thanks for the reply :-) ahhh ok will change the fans around then, thanks for the advice..appreciate it.
Kind Regards N
Hi mate....taken your advice, removed the grill and fixed the fans onto the other side of the radiator, just to confirm...is this correct the fans pulling air from the rad?
http://i50.photobucket.com/albums/f336/spellbound72/rad.jpg
Thanks again.
Regards N
