About 6 months ago I decided my expansion tank was looking real mucky so I gave the whole cooling system a proper clean out. I removed and cleaned the expansion tank and radiator and gave the pipework a good flush with the garden hose. I didn't think to use a proper radiator flush.
I have noticed the expansion tank is slowly getting more and more dirty... the water turning yellow with an oily layer on the surface and brown deposits. Perhaps the system wasn't cleaned thoroughly enough... I doubt that cold water is particularly effective at picking years of oily grime buildup.
I'm now thinking of giving the system another good clean. Someone said that they used a bit of clothes detergent or dishwashing liquid to clean out their system... adding some to the coolant, running idle for a good while to get things circulating and properly heated, then flushing everything out. I'm a little dubious! Does the detergent contain nasty chemicals etc that will eventually cause further corrosion or damage to the radiator and pipework? Or will it be OK so long as the stuff is thoroughly flushed out?
I've been considering using a proper radiator flush product such as Holts Radflush 2 Step. Does anyone have any experience with these products? Would they be any better than the clothes detergent or dishwashing liquid?
Finally, I'm wondering if perhaps there is a more serious issue... I mean there must be a reason why the oil got into the system in the first place, right?! I can understand a reasonable amount of rust... but is it normal to have an amount of oily gunk in the expansion tank? It's a rather old car which has probably seen a fair amount of abuse!
My first thought is a blown head gasket. However, there's no white goo under the oil filler cap, no smoke from the exhaust, both oil and coolant levels seem constant, and I haven't noticed any performance issues. Is it possible that there is a minor failure which is just allowing oil ingress into the cooling system, but no contamination of the oil? Is there anything else I should be considering or checking? Or, is it likely that the grime is just old residue which wasn't cleared out properly?
Any thoughts or advice welcome!
Thanks!
Thanks!
