Radiator for Coolermaster HAF922
13 Dec 2008
I'm wondering what radiator will fit internally/Top. might have to mount the rad inside and mount the fans outside.
Doesn't seem to be enough clearance for a Thermochill PA120.2 + fans on the inside.
Wonder if something like a Black Ice GT Stealth + fans can be mounted internally?
What do you think?
It looks like the standard fitment for dual rads, so a PA120.2 will probably NOT line up.
To be honest this case wont be great for water cooling as the rad would have to really thin so would possibly only cool the CPU only.
Use it for air cooling as its got plenty of puff.
Thanks Deadman, the PA120.2 will probably won't line up, is this because the radiator needs to have 15mm spacing? Sorry I'm not clued up on WC.
I'm thinking single loop for CPU only, would have been better off with the HAF932, but just too big for me.
