Radiator Grills
13 Sep 2009
Maidstone, Kent
I have never used a radiator grill before and have a few questions. Basically I am modding a TJ07 for air cooling and I will be installing 2x 120mm fans using a 120.2 rad grill.
I am getting the fan holes cut for the midplate. However, are the mounting holes in the same position on every 15mm spaced grill? So if I told them to cut 2x 120mm fan holes and drill the mounting holes, would they know what I was on about?
Also, what screws do I need to mount a fan directly onto the grill and to attatch the grill to the case?
Cheers!
Fan holes and spacing are all standard. Just say you want the two fans nestled right next to each other and it'll be fine. That will leave the standard 15mm between the screw holes.
3/8 inch screws for fans (M4? I think - someone confirm). Actually, just standard fan screws you get with case fans :).
Cheers! How about the screws that attach the grill to the case? Are their positions standardised too? I'd just use a nut and bolt to hold that down right?
