- 2 Sep 2007
Any ideas what I can do to fix the leak below: -
Is it actually leaking? It just looks a little dirty. If it is then you will need to isolate both valves (the thermostatic should have cap you screw on instead of the head to isolate it properly). Then drain the radiator, unscrew the fitting clean it up and refit it with new PTFE tape or paste. Then put it back together and bleed the rad once the valves are open.
If no joy, you could diy try some LSX paste.
Mick
