- 17 Jun 2005
- Near Brighton
When you buy a radiator do you get the required mounting screws to mount it to the case or even mount fans to the radiator and then to the case. My radiator i bought 2nd hand so i wasnt sure.
Also, the spacing between each fan on a radiator, is that always a set difference or are there common and uncommon spacing?
