Hi all,
Looking at putting a water cooling loop into my Coolermaster stacker830 case and am struggling to find a place to put the rad. If I go with either a 240mm or a 360mm radiator, I think it will have to go on the floor of the case as with the psu at the top of the case space would be tight. What concerns me with placing the rad at the bottom of the case is the heat from the rad rising up through the case and heating everything up. Should I be concerned with this?
