Radiator Posibilities
5 Feb 2009
Hello All, not quite sure if this is the right section but here it goes.
The BitFenix Shinobi XL is the case in question (Link provided below):
http://www.overclockers.co.uk/showproduct.php?prodid=CA-077-BX&groupid=2362&catid=1850&subcat=
What are the possible watercooling radiator arrangements in this case ? what have people seen / have ?
Wondering if to get one as a mid way before my custom case is finished to suit my new motherboard E-ATX/XL_ATX design
Regards
-Ninja
2 x Phobya Xtreme 200's is the simplest solution.
Will bolt straight onto the 230mm fans, they have adapaters for 180mm - 230mm fans supplied.
Sorry probably should have made it a bit clearer, I already have two loops set up (240 + 120) and (240), I guess I was more asking for dimensions of the spaces they could go.
Sorry for misunderstanding
-Ninja
