Radiator problem
11 May 2011
Farnborough
Ok. I have a dual radiator but I can't fit the 2nd fan in the top because it's too thick and my ram is in the way. Would it be ok to run it with 1 exhaust?
Will be ok but the performance won't be as good as a two fan push pull set up, can you not run a ran outside of the case? If not just keep an eye on temps.
Were in the exact same possition, and I couldnt find a thin fan at OCUK.
the slip stream from scythe looks to be what we need so will have to order from somewhere else
