First off this is going to be probably the easiest question ever!
In regards to a standard watercooling radiator can a fan be mounted either side of it?
I have a CM stacker 830 and will be installing a water cooling loop for the CPU only soon and will consist of a 120mm rad. I would like to mount this all internally. I think the ideal place would be on the side grill or at the back. However - in most pics i have seen it looks like the barbs will get in the way of this.
One other quick question based on the first - If i can mount a fan either side of the rad, would it make a huge difference if I had a fan sucking air onto the rad or sucking it from the rad? guessing sucking into the rad would be better but thought i would ask
