Hi all,
Got a couple of questions about my loop:
- Currently I'm using one EK 360 XE for an i76850k with a Titan X Pascal. I am planning on overclocking both hard - hoping to get the i7 to 4.4 Ghz, and I know my Titan can hit 2 Ghz. Will this single 360 60mm radiator be enough to keep my CPU temp in the 40s-50's under load, with comparable GPU temps? Or should I look at adding another rad to my loop? I could add a 280/240 to the top as exhaust if necessary, or a 140.
- Which mounting position is better - top exhaust or front exhaust? If having it in the front, I was going to have the ports on the bottom so I can have a drain port at the bottom of my case. Anyone have experience on whether or not this is a good idea?
Thanks!
Thanks!
Check out the HW Labs Black Ice Nemesis GTS 240mm, they're great rads.
Nice one. They're great quality rads. I have 2x120 GTX/GS and a 160 GTX going in my rig in the next week or so.
