Permabanned
- 5 Apr 2006
So i'm planning a new build but still undecided on the rads.
I could go for a 360 60mm rad in the front but this would require faster running noisier fans but then again I could go for a 420 45mm rad, would this offer the same level of cooling?
Or I could go for an Alphacool 420 60mm rad but then again faster nosier fans.
That would be at the front of the case, for the top I'm thinking about either a 420 60mm in just a pull config or a 420 30mm in a push/pull config (45mm if it fits).
Which would perform the best?
). Though as you say radiator specs don't tell the whole story, you have to look at the data.
