Hello guys,
I need advice from more expierenced people. I want to build first my custom loop. First about components which i will use in the build.
CPU 8700K will be OC G
2070 MSI armor 8G will be OC
Mainboard Msi z370 a-pro
PC case TT core p5,
Pump from Alphacool eisbecher d5 wih 250ml reservoir ( VP755)
Fans Fractal's HP/S 12.
I know that in this case i can mount only one radiator max 480mm size, but i found 3d printed top mounts for one more 480mm xflow radiator. I know it's overkill but i want tu run fans on almost minimal RPM. The question is which thickness radiator i schould use, 30 or 45? I was considering to buy it from alphacool. Thanks for advice.
PC case TT core p5,
