- 8 Jan 2011
Does anyone go about to prevent radiator vibration from fans?
I used to watercool my hafx and had no kind of vibration noise at all but since moving to the 800d which gives the top radiator much more contact with metal I have been getting horrible vibrating from the fans on to the radiator which i'm guessing then goes on to the chassis.
I have 3x1850rpm Gentle Typhoons @ 800rpm and can hear a faint vibration.
I have 2 phobya fan shrouds on 2 of the fans with anti vibration pads inbetween the shroud/fan and the shourd/radiator on 1 of them and then 1 pad on the 2nd shroud+fan.
If you get me.
Just wondered if anything went and done it or got it
If you get me.
