I think I've started to get somewhere with my custom water kit. Planned spec so far is:
Reservoir: Alphacool Repack-cooling slot
Pump: Swiftech MCP655 (from good ol’ OcUK)
CPU block: Swiftech Apogee (OcUK again)
Tubing: ½” Tygon
I'm going to get distilled water and coolant conditioner from Halfords (see, I read at least some of the watercooling sticky)
Now i need some advice on the rads...
I have an Akasa Eclipse 62 case and, ideally would be able to put the rad inside.
Has anyone fitted a double radiator into an Eclipse?
Is there likely to be any cooling gain/loss if I put two single rads in sequence but in different locations?
Any suggestions welcomed
Tubing: ½” Tygon
