- 18 Mar 2015
I'm planning on building into a corsair air 240 case for my first build and as such there is a bit of a limitation on radiator length, i want a front mounted 240mm radiator set up in push/pull format and to my knowledge the maximum length radiator i can lever in is 280mm. With this in mind what would be the best thickness of radiator to go for? I've been assuming that a thicker radiator equals more surface area equals better cooling but I have no idea for sure. Help?
I have 4 Coolermaster Jetflo fans ready to go on whatever radiator is most recommended...
