Radio Code Help? - Fiesta
Press 1 repeatedly until you get the digit you want.
Press 2 repeatedly until you get the digit you want.
Press 3 repeatedly until you get the digit you want.
Press 4 repeatedly until you get the digit you want.
Pretty sure that's right but it's late.
Bit of an art to it. Instead of punching in the numbers, for example.. if your code is 1742, you'd hit 1 once 2 seven times 3 four times and 4 two times. You then hit 5 to okay it. I hope I explained it well enough :p I learnt this by trial when my code had a 9 in it and I was shouting at the unit, THERE IS NO NINE!!
