Radio Code
31 Oct 2003
Derby, UK
After some problems with the battery on my 1998 rover 400, the radio now needs the code but i havent got it (from what ive looked through). How do i go about obtaining this as i really get bored without music :(
Rob
I needed the code for mine, Nearly had to send off for it,
The dealership wanted £9.95 for it! Luckily i found mine in the manuel, as there all different you need to either find it in a service book, or pay the £10 for a new code.
Sorry.
The_Dark_Side said:
pop it in a plastic bag and out it in the freezer compartment of your fridge.
leave overnight.
voila,code free radio-cassette.
That has worked for me in the past with Truck radio's, helps if your pulling a reefer trailer though... :o
Iirc, the cold has some effect on the microchip, re-setting the code. :confused:
If you post the exact model number of the radio / its serial numbers etc then it may be possible to find some info on it :)
Cheers guys, i found a random number on a piece of paper in a folder with all the service/maintenance invoices, tried it and voila!
Cheers :)
