Radio Question
28 Jan 2005
Southport
hi all,
I have just recently replaced my factory head unit with a new one it all works fine it just skips tracts as I go over bumps,its not held in by anything so what do I need to hold it in? Do i use the old standard cage from the factory radio?
If the old head unit is the same size as the new one then use the same cage... try it out... see if it fits. However i do not know if fitting it in a cage is going to help solve the skipping...
my new head unit skips over speed bumps... simple way to solve it was to drive slower over them ;)
