- 1 Jan 2012
- Scottish Borders - UK
Guys...
I fitted both my Antec Kuhlers in the top of my R3 last night.
I had to move them away from the rear of the case as they would foul on memory/motherboard io.
Doesn't look too bad-ish. I simply drilled one hole per cooler. As you can see from the pics one hangs down at a little angle, but nothing major. Simply one corner not screwed in. (could do this, but would require another hole being drilled.
As you can see from the pic from the top, one fan is partially covered but it doesn't seem to be making a difference.
My question is what can I do about the open mesh areas now when viewed from the top? I have some packaging foam I was thinking of painting/colouring in black and wedging it between the fans and motherbaord area to fill that space up.
Any ideas?
thanks
Any ideas?
thanks
