RAID 0 HELP
30 Oct 2006
I HAVE A ASUS A8N32 SLI MOBO IM TRYING TO INSTALL A RAID CONFIGURATION
I CAN SET UP AN ARRAY BUT WHEN I INSTALL WINDOWS A MESSAGE COMES UP NO HARD DISKS FOUND THE DISKS ARE CONNECTED TO SATA1AND2 AS I SAID THEY APPEAR IN THE ARRAY BUT WHEN I INSTALL THE OS IT SAYS NO DISKS FOUND PLEASE HELP.......
There is a special program in Windows install to detect those people who don't know the position of the caps lock.
Alternatively read the page in your manual titled 'creating a RAID driver disk', particularly the bootom bit which mentions using the F6 key (5-41_.
The link above is for the Silicon Image controller (labeled Sata_Raid1 on the MB) if you have it connected to the nvidia connector you will have to use the install method in the manual.
