Raid controller on p6t deluxe
25 Jun 2008
I cant seem to install the RAID controller driver for this in Vista 64.
Got two raptors as my boot drive so made the driver disk on a floppy, installed Vista 64 ultimate but it didnt ask for it, just installed anyway. Now its showing up in device manager as not installed.
Tried updating it and pointing it to the floppy and also a downloaded driver from the site but Vista just says it cant find it, also failed trying searching online.
Anyone any ideas why?
Cheers,
Ash
It's ICH10R, so Vista should install on it without the need to load any extra drivers.
If you're able to look at Device Manager then I assume that it did install ok. You can install the Intel Matrix Storage Manager too if you want.
its showing up in device manager with a ! next to it and:
The drivers for this device are not installed. (Code 28)
To reinstall the drivers for this device, click Reinstall Driver.
It may well be the Marvell drivers that aren't installed. They don't really need to be installed if you're not going to be using the Marvell controller for RAID.
Which device is the ! displayed beside in the Storage Controllers part of Device Manager.
