Raid issue when O/Clockiing
2 Jan 2004
Kent
See sig for spec.
If i imput settings in bios which pc does not like,when it reboots it tells me the nvidia drivers for raid are missing and will not start, so i then have to go back in bios set all 6 sata drives to raid,reboot and then its fine,so then back to bios and put original settings back and pc is fine and healthy.
Any one else have this issue.
I know there was an issue with the evga board and the sata drives but not this issue.
This is completely normal. It's the PC resetting the BIOS to defaults after it's failed to restart using the settings you've entered. Save your basic settings so you can reload them easily after this happens.
