When you set up a RAID1 mirror, you basically run two drives in parallel. The data is identical on both and if one fails, the other takes over. Ideally both drives should be the same make, model and capacity but it will work with different drives.
For example I run a Seagate 250GB and a Hitachi 320GB in RAID1, they both run at a similar speed but I can only use 250GB in total and the performance will only be that of the slowest drive.
The problem with your proposed setup is you want to mirror a blazing RAID0 SSD setup with a slow, conventional hard drive. I'm not an expert in RAID arrays but at the very least I don't think it would be making best use of your hardware.
Based on what you have said, I'm thinking a RAID5 array would be best and forget about the mirror altogether and keep one (or more) of your 8 drives in a box as a spare.
Definitely ask in the hard drive forum though because they are the experts, I've only ever used conventional disks - it might be a different ball game with SSDs.
