If youve already set it up, its probably not worth re-installing, though if you havent installed yet you have 2 options, RAID0 or RAID1, RAID0 has the better performance increase but if either drive fails you lose everything, as such you have doubled your chance of failiure, RAID1 has marginal performance benefits but protects against such failiures as each disk mirrors what the other has on it, so if one drive fails, you still have the data on the other drive. So it depends what you want from your RAID, note however RAID1 is not the same as back up and does not prevent against corruption, if files become corrupt you still lose the data, it merely protects against drive failiure
