Hi,
Raijintek have today released the version of the Arcadia that has done so well in the market already. This time it comes with a windowed side panel and few different design features.
Check it out below:
Raijintek Arcadia II Midi-Tower Gaming Case - Black Window @ £34.99 inc VAT
Premium brushed aluminium case, Excellent value for money, Side panel made from acrylic glass, 1x 120mm fan pre-installed
The Raijintek Arcadia II is a high quality Midi-Tower case with a high-end look. Thanks to its brushed aluminum finish, the case also offers excellent value for money. Raijintek have included many convenient and premium features such as an acrylic glass side panel, magnet dust filters and space for up to five 120mm fans.
The Raijintek Arcadia II at a glance:
- Premium case at a great price-point
- Acrylic glass side panel
- Extensive customisation options
- 1x 120mm fan pre-installed and space for up to 4 others (5 in total)
Features of the Raijintek Arcadia II in detail:
The Raijintek Arcadia II is a Midi Tower case designed to hold motherboards from ITX up to ATX form factors. The case has a striking brushed aluminum finish, as well as a transparent acrylic side panel which lets users showcase their build's components.
The case offers highly efficient cooling with the ability to to install up to a total of five 120mm fans in the case. That's two 120mm fans in the front, two additional 120mm fans in the case's roof and one 120mm fan in the rear (preinstalled).
The Arcadia II has additionally been designed to work with the latest water cooling hardware. A 240mm radiator can be installed in the front of the case and an additional 240mm radiator in the roof.
In addition a magnetic dust filter ensures delicate components inside are protected.
As for storage there is room for a single 5.25" drive, two 3.5" drives or two 2.5" drives. The I/O panel includes x1 USB3.0, x2 USB2.0 and a HD Audio jack.
Specification:
- Colour: Black
- Dimension(mm): D375xW185xH426
- Material: SPCC 0.5mm
- Motherboard: ATX, Micro ATX, ITX
- I/O Panel:x1 USB3.0, x2 USB2.0, HD Audio jack
- Drive Bays: 5.25"x1 3.5"x2 ; 2.5"HDDx2
- Cooling System Front:120mmx2
- 240mm radiator (optional)
- Rear:120mmx1 (pre-installed)
- Top: 120mmx2 ; 240mm radiator (optional)
- PCI slot 7
- VGA Card 340mm
- CPU Cooler 160mm
- Filter On bottom
- Side panel: Acrylic
Only £34.99 inc VAT.
ORDER NOW
Check it out below:
Specification:
- Colour: Black
- PCI slot 7
- VGA Card 340mm
- CPU Cooler 160mm
- Filter On bottom
ORDER NOW
