Hi,
Raijintek have released a new range of fans from your standalone colours to RGB offering you a selection of suitable fans for any build.
The range comes in 2 styles, style one is a solid colour choice of either Red, Blue, Green and white with style 2 being RGB coming in packs of 1, 2 and 3 fans.
Styles 1:
The IRIS 12 series combines optimised Eleven fan blade design to provide high-volume air delivery with less noise and turbulence, O-type LED ring and 15pcs LEDs to brings visible colour and brightness uniformity from all directions, Hydraulic Bearing with Low-Noise Design, and Anti-Vibration rubber pads on all corners. Standard with LEDs incorporated with transparent frame and blades, IRIS 12 series is not only insuring your case to be the centre of attraction and a spot light to chassis, but its optimised fan blade and housing design also provide outstanding air flow and cooling performance for your PC's motherboard and CPU.
Style 2:
6 port RGB LED hub and remote controller (for 2 & 3 pack), you can set your IRIS 12 Rainbow RGB fans to stun with fading, breathing, blinking and single colour LED modes. The IRIS 12 series combines optimised Eleven fan blade design to provide high-volume air delivery with less noise and turbulence, O-type LED ring and 15pcs LEDs to brings visible color and brightness uniformity from all directions, Hydraulic Bearing with Low-Noise Design, and Anti-Vibration rubber pads on all corners. Standard with LEDs incorporated with transparent frame and blades, IRIS 12 series is not only insuring your case to be the centre of attraction and a spot light to chassis, but its optimised fan blade and housing design also provide outstanding air flow and cooling performance for your PC’s motherboard and CPU.
Raijintek IRIS 12 PWM 120mm LED FAN - Blue @ £8.99 inc VAT https://www.overclockers.co.uk/raijintek-iris-12-pwm-120mm-led-fan-blue-fg-019-rt.html
Raijintek Iris LED Fan, Blue LED, 120mm, 800 - 1800 rpm, 42.17 cfm, 26,5 dba
Only £8.99 inc VAT.
ORDER NOW
Raijintek IRIS 12 PWM 120mm LED FAN - Green @ £8.99 inc VAT https://www.overclockers.co.uk/raijintek-iris-12-pwm-120mm-led-fan-green-fg-01a-rt.html
Raijintek Iris LED Fan, Green LED, 120mm, 800 - 1800 rpm, 42.17 cfm, 26,5 dba
Only £8.99 inc VAT.
ORDER NOW
Raijintek IRIS 12 PWM 120mm LED FAN - Red @ £8.99 inc VAT https://www.overclockers.co.uk/raijintek-iris-12-pwm-120mm-led-fan-red-fg-01e-rt.html
Raijintek Iris LED Fan, Red LED, 120mm, 800 - 1800 rpm, 42.17 cfm, 26,5 dba
Only £8.99 inc VAT.
ORDER NOW
Raijintek IRIS 12 PWM 120mm LED FAN - White @ £8.99 inc VAT https://www.overclockers.co.uk/raijintek-iris-12-pwm-120mm-led-fan-white-fg-01f-rt.html
Raijintek Iris LED Fan, White LED, 120mm, 800 - 1800 rpm, 42.17 cfm, 26,5 dba
Only £8.99 inc VAT.
ORDER NOW
Raijintek IRIS 12 RGB LED PWM 120mm Fan @ £12.95 inc VAT https://www.overclockers.co.uk/raijintek-iris-12-rgb-led-pwm-120mm-fan-fg-01b-rt.html
Raijintek Iris RGB Fan, 800- 1800 rpm, 42.17 CFM, 26.5 dba
Only £12.95 inc VAT.
ORDER NOW
Raijintek IRIS 12 RGB LED PWM 120mm Fan with Controller - Twin Pack @ £31.99 inc VAT https://www.overclockers.co.uk/raij...-fan-with-controller-twin-pack-fg-01c-rt.html
Raijintek Iris RGB Fan, 2 fans in one pack, Remote controlled, 800- 1800 rpm, 42.17 CFM, 26.5 dba
Only £31.99 inc VAT.
ORDER NOW
Raijintek IRIS 12 RGB LED PWM 120mm Fan with Controller - Triple Pack @ £39.95 inc VAT https://www.overclockers.co.uk/raij...an-with-controller-triple-pack-fg-01d-rt.html
Raijintek Iris RGB Fan, 3 fans in one pack, Remote controlled, 800- 1800 rpm, 42.17 CFM, 26.5 dba
Only £39.95 inc VAT.
ORDER NOW
ALL RAIJINTEK FANS AVAILABLE HERE
ALL RAIJINTEK COOLERS AVAILABLE HERE
Styles 1:
Style 2:
Only £8.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
