**RAIJINTEK NEW COOLER AND FAN RANGE**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Raijintek have been working on making some new coolers and fans to add to the current range. They have released 2 new cooler ranges and 2 new fan ranges as shown below.
LETO Coolers
The LETO series, Raijintek’s 120mm slim-type CPU cooler, is "Designed in Germany“, manufactured by several patents to reach advanced performance, high quality & workmanship. It is a slim type 120mm cooler (D:50mm) and height is 157mm, very suitable for most ATX chassis. With performing 120mm LED PWM fan, Anti-vibration rubbers and supporting all modern sockets, THEMIS 8 is your professional choice and a budget price of cooling .
The LETO cooler has been designed with an LED fan and a black matte finish which was missing on the Themis. The LED fan on the LETO is PWM controlled with a range of 800rpm - 1800rpm with an Airflow of 65.5CFM and up to 28.5 decibels.
Raijintek Leto White LED Slim 120mm CPU Cooler @ £26.99 inc VAT https://www.overclockers.co.uk/raijintek-leto-white-led-slim-120mm-cpu-cooler-hs-02a-rt.html
Socket Compatibilty: Intel: LGA 775/ 115x/ 1366/ 201x/ 2066, AMD Socket: AM4/ AM3+/ AM3/ AM2+/ AM2/ FM2+/ FM2/ FM1
Only £26.99 inc VAT.
ORDER NOW
Raijintek Leto Red LED Slim 120mm CPU Cooler @ £26.99 inc VAT https://www.overclockers.co.uk/raijintek-leto-red-led-slim-120mm-cpu-cooler-hs-02b-rt.html
ORDER NOW
Raijintek Leto Blue LED Slim 120mm CPU Cooler @ £26.99 inc VAT https://www.overclockers.co.uk/raijintek-leto-blue-led-slim-120mm-cpu-cooler-hs-02c-rt.html
ORDER NOW
Juno - X Coolers
The Juno-X is a small, compact and light CPU cooler, With a TDP of maximum 70 watts optimal for HTPCs and other small computers. The design is compared to the concept of the Zalman cooler in this version is made of aluminum and a powerful 92mm PWM fan. The 92mm PWM fan ranges from 1200rpm to 2500rpm with a maximum 26 decibel noise output. The design not only coos the CPU but the components around it as well.
Raijintek Juno-X CPU Cooler - Black @ £8.99 inc VAT https://www.overclockers.co.uk/raijintek-juno-x-cpu-cooler-black-hs-02d-rt.html
Compact CPU cooler from Raijintek, 92mm PWM fan, 88.35m³ / h / 0.94mm H2O, Aluminum radial design, high compatibility with AMD & Intel
Only £8.99 inc VAT.
ORDER NOW
Raijintek Juno-X CPU Cooler - Red LED @ £8.99 inc VAT https://www.overclockers.co.uk/raijintek-juno-x-cpu-cooler-red-led-hs-02e-rt.html
Compact CPU cooler from Raijintek, RED LED, 92mm PWM fan, 88.35m³ / h / 0.94mm H2O, Aluminum radial design, high compatibility with AMD & Intel
Only £8.99 inc VAT.
ORDER NOW
RGB Fans
RAIJINTEKs first LED/RGB fan, AURAS 12 fan series, is a 120 x 25 mm O-type LED fan of which the RGB type is 256 multi-colours. On the controller box (RGB type), users can easily adjust fan speed as well as fan colours by clicking “MODE”, “LOCK”, and “SPEED” button. Anti-vibration rubber pads are used in all four corners to minimize movement and noise. The optimized fan blade and housing design provides outstanding air flow, enhances static pressure and cooling performance. O-type LED ring brings visible colour and brightness uniformity from all directions and adds spot light to the chassis.
Raijintek Auras 12 RGB LED Fan with Controller 120mm - 3 Pack @ £26.99 inc VAT https://www.overclockers.co.uk/raij...n-with-controller-120mm-3-pack-fg-013-rt.html
3 x Aura 12 RGB Fan, 120mm, 1200 RPM, 39.8 CFM, 24.8 d BA
ORDER NOW
Raijintek Auras 12 RGB LED Fan with Controller 120mm - 2 Pack @ £18.95 inc VAT https://www.overclockers.co.uk/raij...n-with-controller-120mm-2-pack-fg-012-rt.html
Only £18.95 inc VAT.
ORDER NOW
LED FANS
Raijintek presents with the Auras 12 the first fan series of the manufacturer, which has a Integrated LED lighting. In doing so, Raijintek relies on an O-type LED ring to provide the outstanding colours and an even offer brightness in all directions. Of course, the fan can also convince with its performance values, which are 101.43 m³ / h delivery volume and maximum 1.62 mm H2O static pressure. The fans PWM function allows for a variable speed range of 800 - 1800 revolutions per minute.
Raijintek Auras 12 White LED PWM Fan 120mm - 2 Pack @ £15.95 inc VAT https://www.overclockers.co.uk/raijintek-auras-12-white-led-pwm-fan-120mm-2-pack-fg-014-rt.html
Black Fan, Set of 2, 120 mm format with PWM function, 800 -1,800 rpm, max. 101,43 m³ / h Delivery volume, max. 1.62 mm H2O static pressure, LED ring with white lighting
Only £15.95 inc VAT.
ORDER NOW
Raijintek Auras 12 Red LED PWM Fan 120mm - 2 Pack @ £15.95 inc VAT https://www.overclockers.co.uk/raijintek-auras-12-red-led-pwm-fan-120mm-2-pack-fg-015-rt.html
Black Fan, Set of 2, 120 mm format with PWM function, 800 -1,800 rpm, max. 101,43 m³ / h Delivery volume, max. 1.62 mm H2O static pressure, LED ring with Red lighting
ORDER NOW
Raijintek Auras 12 Blue LED PWM Fan 120mm - 2 Pack @ £15.95 inc VAT https://www.overclockers.co.uk/raijintek-auras-12-blue-led-pwm-fan-120mm-2-pack-fg-016-rt.html
Black Fan, Set of 2, 120 mm format with PWM function, 800 -1,800 rpm, max. 101,43 m³ / h Delivery volume, max. 1.62 mm H2O static pressure, LED ring with Blue lighting
ORDER NOW
Raijintek Auras 12 Green LED PWM Fan 120mm - 2 Pack @ £15.95 inc VAT https://www.overclockers.co.uk/raijintek-auras-12-green-led-pwm-fan-120mm-2-pack-fg-017-rt.html
Black Fan, Set of 2, 120 mm format with PWM function, 800 -1,800 rpm, max. 101,43 m³ / h Delivery volume, max. 1.62 mm H2O static pressure, LED ring with Green lighting
ORDER NOW
All Raijintek Products Available Here
