Hi,
The Orcus has now been been improved with a better flow rate and better fans. The Orcus now includes addressable RGB on the reservoir and on the fans for full light customisation in your PC. You can control the lighting of the cooler using either the ADD Header on the Motherboard or using the included remote control.
Raijintek Orcus RBW Addressable LED AIO Water Cooling Unit - 140mm @ £89.99inc VAT
Addressable RGB Fans, 140m Radiator and Fan, Comaptible with Latest AMD and Intel Sockets, 2 Year Warranty
Radiator Size: 140 x 27 x 272 mm (W x H x D)
Filling Volume: 135ml ±10%
Fans:
1x 140 mm Raijintek Iris
Connector: 4-Pin PWM
Bearings: Hydraulic
RPM: 400~1500 R.P.M.
Volume: max. 30 dB(A)
Flow Volume: 65.19 CFM
Static Pressure: max. 1.22 mm H2O
Current: 0,14 A
Power Consumption: 1,68 Watt ± 10 %
Pump:
Size: 69,5 x 33 x 40 mm (W x H x D)
Bearings: Ceramic
Flow Volume: max. 66 Litre/h
Flow Height: 1,3 m
Volume: 25 dB(A)
RPM: 5.000 RPM ± 10 % at 12 V
Current: 180 mA
Power Consumption: 1.68 Watts ± 10 %
Compatibility (Socket):
Intel 775, 1150, 1155, 1156, 1366, 2011, 2066
AMD AM2, AM2+, AM3, AM3+, AM4, FM2, FM2+
Hose Length: approx. 35 cm
Manufacturer's Guarantee: 2 Years
Only £89.99 inc VAT.
ORDER NOW
Raijintek Orcus RBW Addressable LED AIO Water Cooling Unit - 280mm @ £109.99 inc VAT
Addressable RGB Fans, 280m Radiator and 2 x 280mm Fan, Comaptible with Latest AMD and Intel Sockets, 2 Year Warranty
Radiator Size: 311×138×28 mm (W x H x D)
Filling Volume: 200ml ±10%
Fans:
2x 140 mm Raijintek Iris
Bearings: Hydraulic
Current: 0,14 A
Pump:
Bearings: Ceramic
Flow Height: 1,3 m
Volume: 25 dB(A)
Current: 180 mA
Only £109.99 inc VAT.
ORDER NOW
Check out the rest of the range below:
Raijintek Orcus RGB AIO Water Cooling Unit - 120mm @ £69.95 inc VAT
0R100080, All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
Only £69.95 inc VAT.
ORDER NOW
Raijintek Orcus RGB AIO Water Cooling Unit - 240mm @ £89.99 inc VAT
0R100069, All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
ORDER NOW
Raijintek Orcus RGB AIO Water Cooling Unit - 360mm @ £119.99 inc VAT
0R100081, All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
Only £119.99 inc VAT.
ORDER NOW
Raijintek Orcus Core RGB AIO CPU Water Cooling Unit - 240mm @ £69.95 inc VAT
0R100070, All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
ORDER NOW
Raijintek Orcus Core RGB AIO CPU Water Cooling Unit - 360mm @ £99.95 inc VAT
0R100082, All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
Only £99.95 inc VAT.
ORDER NOW
Raijintek Orcus Core RGB AIO - 240mm + 2x Noiseblocker NB-eLoop Fan B12-PS @ £79.99 inc VAT
Bundle with Raijintek's complete water cooling AiO Orcus Core RGB in a combination pack, Two powerful Noiseblocker BlackSilent Pro 120mm fan
Only £79.99 inc VAT.
ORDER NOW
Raijintek Orcus Core RGB AIO - 360mm + 3x Noiseblocker NB-eLoop Fan B12-PS @ £109.99 inc VAT
Bundle with Raijintek's complete water cooling AiO Orcus Core RGB in a combo pack with three powerful Noiseblocker NB eLoop fans 120 mm fans
ORDER NOW
Fans:
Bearings: Hydraulic
Current: 0,14 A
Pump:
Bearings: Ceramic
Flow Height: 1,3 m
Volume: 25 dB(A)
Current: 180 mA
ORDER NOW
Fans:
Bearings: Hydraulic
Current: 0,14 A
Pump:
Bearings: Ceramic
Flow Height: 1,3 m
Volume: 25 dB(A)
Current: 180 mA
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
