Hi,
Raijintek now offers a broad portfolio of efficient and powerful All-in-One water cooling systems ranging from entry-level to high-end systems. The Raijintek Orcus counts itself among the latter group.
The compact water cooling system consist of the two same fundamental components: The radiator and the heatsink. The Orcus Core comes with a 240 mm dual-design radiator and a pump which is situated just in front of the tubes instead of the Reservoir. Only the reservoir is integrated into the cooler. The effect of this is to reduce the total height, thereby making the installation of the solid copper heatsink much more convenient.
A transparent window not only allows you to monitor the volume of coolant, it also comes with a small wheel that serves as a through flow indicator. The high-performance pump is located in the vicinity of the radiator. Its graphite and ceramic bearings ensure a maximum throughput of 66 L per hour at 5000 RPM with a maximum volume of 25 dB(A).
The hydraulic bearings of both Iris fans transfer heat away from the radiator with ease, and for this important reason Raijintek has made them extremely durable and robust for over the long term. At a maximum of 1.800 RPM the fans are quite capable of pushing a significant volume of air.
Compatible with most major sockets:
Intel Socket Support 775, 1150, 1155, 1156, 1366, 2011, 2066
AMD Socket Support: AM2(+), AM3(+), AM4, FM2(+)
Raijintek Orcus RGB AIO Water Cooling Unit - 240mm @ £99.95 inc VAT
All in one cooler, RGB Lighiting, Intel Socket Support 775 / 1150 / 1155 / 1156 / 1366 / 2011 / 2066, AMD Socket Support: AM2(+) / AM3(+) / AM4 / FM2(+)
Complete water cooling system with easy installation
Pre-filled and maintenance-free
High cooling performance thanks to 38 mm thick dual-radiator
Two Iris 120 mm RGB-LED PWM fans
Comes bundled with RGB controller
Quiet 25 dB(A) pump
Improved compatibility
Only £99.95 inc VAT.
ORDER NOW
Raijintek Orcus Core RGB AIO CPU Water Cooling Unit - 240mm @ £79.99 inc VAT
Quiet 25 dB(A) pump
Only £79.99 inc VAT.
ORDER NOW
All Raijintek Coolers available here
All Raijintek Fans available here
Quiet 25 dB(A) pump
ORDER NOW
Quiet 25 dB(A) pump
ORDER NOW
