** RAIJINTEK PAEAN & FRIENDS **
OcUK Staff
26 Nov 2014
Stoke
Introducing the Raijintek Paean, an ATX bench table/show case with aluminium and tempered glass construction. The Paean is designed with enthusiasts in mind, giving the user space for 360mm radiators, 310mm VGA cards, six HDD's and 200mm PSU's. Due to it's dual compartment construction, cable management can be hidden effectively so you can show off your system in style. Full ATX motherboard support is included, and the glass panels are suspended using 8mm aluminium tubes for a unique look. Once assembled this chassis looks really nice, and is another positive step forward for Raijintek. Stock is available today!
In addition, in stock now, we have the Thetis and Metis Plus. The Thetis is a new version of the Styx with ATX motherboard support. There is also support for 240mm radiators, 280mm VGA cards, 170mm CPU coolers and there is a 120mm LED fan installed in the rear. Same as the other models in this range, the Thetis exterior is made from aluminium as standard. The Thetis is available with either normal aluminium side panels, or a pair of tempered glass side panels depending on your requirement. We have both Black and Silver options in stock today!
In addition, we also have the Metis Plus, an upgrade to the Metis which took onboard feedback from the community and has improved ventilation due to a 120mm fan option at the top of the case. In addition, there is more ventilation holes for the pre-installed 120mm LED fan (an upgrade from the regular 120mm fan in the Metis) and the ability to move the HDD tray, something not possible on the original Metis. Other than that, it's still the same Metis that has proved extremely popular since it's launch. The Metis Plus is available in 7 flavours, Black/Silver/Red/Blue/Green/Gold and White. All are in stock now!
Raijintek Paean Aluminium ATX Bench Table/Showcase - Black @ £149.99 inc VAT https://www.overclockers.co.uk/raij...atx-bench-table-showcase-black-ca-039-rt.html
Design art at its best by RAIJINTEK – Introducing the Paean - a 4mm aluminum ATX bench table chassis with a pair of 5mm tempered glass side panels.
Only £149.99 inc VAT.
ORDER NOW
Raijintek Thetis Aluminium ATX Cube - Black Window @ £86.99 inc VAT https://www.overclockers.co.uk/raijintek-thetis-aluminium-atx-cube-black-window-ca-03a-rt.html
Meet the Thetis - RAIJINTEK’s new Aluminum ATX case. It is an upgraded version of STYX and has a remarkably elegant appearance with good compatibility with hardware.
Only £86.99 inc VAT.
ORDER NOW
Raijintek Thetis Aluminium ATX Cube - Silver Window @ £86.99 inc VAT https://www.overclockers.co.uk/raijintek-thetis-aluminium-atx-cube-silver-window-ca-03b-rt.html
ORDER NOW
Raijintek Thetis Classic Aluminium ATX Cube Case - Black @ £86.99 inc VAT https://www.overclockers.co.uk/raijintek-thetis-classic-aluminium-atx-cube-case-black-ca-03c-rt.html
ORDER NOW
Raijintek Thetis Classic Aluminium ATX Cube Case - Silver @ £86.99 inc VAT https://www.overclockers.co.uk/raij...aluminium-atx-cube-case-silver-ca-03d-rt.html
Raijintek Metis Plus Aluminium Mini-ITX Case - Black Window @ £52.99 inc VAT https://www.overclockers.co.uk/raij...ium-mini-itx-case-black-window-ca-03e-rt.html
The Metis Plus - RAIJINTEK’s new aluminum MINI-ITX case. It is an upgraded version of METIS where pure innovation meets classic design.
Only £52.99 inc VAT.
ORDER NOW
Raijintek Metis Plus Aluminium Mini-ITX Case - Silver Window @ £52.99 inc VAT https://www.overclockers.co.uk/raij...um-mini-itx-case-silver-window-ca-03f-rt.html
ORDER NOW
Raijintek Metis Plus Aluminium Mini-ITX Case - Red Window @ £52.99 inc VAT https://www.overclockers.co.uk/raij...inium-mini-itx-case-red-window-ca-03g-rt.html
ORDER NOW
Raijintek Metis Plus Aluminium Mini-ITX Case - Blue Window @ £52.99 inc VAT https://www.overclockers.co.uk/raij...nium-mini-itx-case-blue-window-ca-03h-rt.html
ORDER NOW
Raijintek Metis Plus Aluminium Mini-ITX Case - Gold Window @ £52.99 inc VAT https://www.overclockers.co.uk/raij...nium-mini-itx-case-gold-window-ca-03i-rt.html
ORDER NOW
Raijintek Metis Plus Aluminium Mini-ITX Case - Green Window @ £52.99 inc VAT https://www.overclockers.co.uk/raij...ium-mini-itx-case-green-window-ca-03j-rt.html
ORDER NOW
Raijintek Metis Plus Aluminium Mini-ITX Case - White @ £54.95 inc VAT https://www.overclockers.co.uk/raijintek-metis-plus-aluminium-mini-itx-case-white-ca-03k-rt.html
Only £54.95 inc VAT.
ORDER NOW
Love the bench table, other cases I'm not sure about, not a lot of front intake ventilation as it looks....
the thetis would have been perfect apart from the windowed side would be facing a wall on my desk :(
. i thought about moving the room around but i have an rj45 socket smack in the middle of the wall, which would look out of place. so far its still going to be the Pro M glass... if get one before they are snapped up
