** RAIJINTEK WATERCOOLING **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Raijintek RAIAQUA-T1 Water Additive @ £8.99 inc VAT
RAIAQUA-T1, is the best partner for PC Liquid cooling system, including functions of anti-freeze, preventing PC cooling system from corrosion and cavitation, anti-rusting and water scale reducing. Additionally to clear coolant, RAIJINTEK also provides 3 small bottles of color dye (Green, Red & Blue) for your scheme and by your convenience.
Specification:
- Main composition Water 95% & Propylene glycol 5%
- Volume 500ml
- Anti-freezing temperature -5?
- Life 2 years
- Color Transparent
- Accessory Green dye (10ml), Red dye (10ml), Blue dye (10ml), Dropper
Only £8.99 inc VAT.
ORDER NOW
Raijintek RAI-R10 Reservoir, 150mm - Blue @ £29.99 inc VAT
Raijintek Atlantis series tube reservoir, RAI-R10, is best partner for Liquid cooling system. Made from high quality POM & PMMA, RAI-R10 provides water cooling DIY enthusiasts a durable solution, reliable performing, and light weight and crystal reservoir. Not only quality and performing, RAI-R10 is also with water fall design inside and provides several anodize colours for best choose. Get RAI-R10 reservoir to feel the quality of your PC cooling system and enjoy of whichever colour you can choose.
Features:
- Manufactured of high quality POM and PMMA material
- Durable solution and reliable performing.
- Lightweight crystal acrylic reservoir
- Special Water fall design inside
- Several Anodize colours Ultimate design for custom PC water cooling
- Max Working temperature 57.8?(136?)
Specification:
- Capacity 200 ml
- Screw Threads G 1/4"
- Weight 220g
- Material Aluminum + Acrylic
Only £29.99 inc VAT.
ORDER NOW
Raijintek RAI-R10 Reservoir, 150mm - Gold @ £29.99 inc VAT
ORDER NOW
Raijintek RAI-R10 Reservoir, 150mm - Red @ £29.99 inc VAT
ORDER NOW
Raijintek RAI-R10 Reservoir, 150mm - Black @ £29.99 inc VAT
ORDER NOW
Raijintek RAI-R20 Reservoir, 250mm - Blue @ £33.95 inc VAT
Only £33.95 inc VAT.
ORDER NOW
ORDER NOW
Raijintek RAI-R20 Reservoir, 250mm - Black @ £33.95 inc VAT
ORDER NOW
Raijintek RAI-R20 Reservoir, 250mm - Red @ £33.95 inc VAT
ORDER NOW
Raijintek RAI-R20 Reservoir, 250mm - Gold @ £33.95 inc VAT
ORDER NOW
Raijintek RAI-PM5 Pump & Stand @ £53.99 inc VAT
Only £53.99 inc VAT.
ORDER NOW
Raijintek VWB-C1 VRAM Water Cooler - Universal @ £25.99 inc VAT
Only £25.99 inc VAT.
ORDER NOW
Raijintek CWB-C1 CPU Water Cooler - Universal @ £51.95 inc VAT
Only £51.95 inc VAT.
ORDER NOW
Raijintek GWB-C1 VGA Water Block - Universal @ £36.95 inc VAT
Only £36.95 inc VAT.
ORDER NOW
Wow some pretty kit here. The pump is an interesting one, flow seems low (but a decent 4.5m of head), more than enough for anything up to a few blocks.
Love the introduction of more universal VRM cooling.
The last CPU block is the only thing out of that page i think is a little sketchy. Only because the finish gives it a cheap look, i am sure it performs as well as any other entry level blocks. Raijintek have always bee great value at cooling when it comes to air, lets hope they bring this to the water side of things.
