I want to connect gpu and was wondering what fluid I can use and what hose and connectors are needed?
is distilled water ok on its own for say 6 months and then replace every 6 months , or does it have to be anti fungal etc?
does piping Id and od have to be precise i.e 9.5mm /12.5mm so 10mm by 13mm would not fit ?
thanks in advance
thanks in advance
