... or did you mean Rail?Steve-O 2006 said:a raid??? I have a graphics card and dont think I have a raid... or did you mean Rail?
It's important to remember that even though there are two "independent" 12V lines, they still draw from the same main source. It's highly unlikely that there are two separate 120VAC:12VDC power conversion devices in a PSU; this would be much too costly and inefficient. There is only one 12VDC source, and the two lines draw from the same transformer. Each line is coming from the same 12VDC source, but through its own "controlled gateway".
PSU makers' specs are misleading in that thay rate the current capacity of each 12V rail independently. What really matters is the total 12V current: Generally, up to 20A is available on any one 12V line assuming the total 12V current capacity of the PSU is not exceed.
Yes one source. No not more efficiently, probably less. But it does stop the overload of any one connection (and any associated voltage drop), which is very unlikely anyway. When you buy the PSU look for the combined maximum wattage for the 12v. Then divide it by 12, gives you the maximum 12v current. Don't just add the rails together.xirokx said:so if even on a dual rail PSU there is one main rail is the difference that power is supplied more efficiently through diff rails? Therefore not overloading the cables?
How does someone know if the rails are 20a give or take when purchasing a new psu?
