Rain Meter
Copy a shortcut to the .exe file and place it in here:
C:\Users\*username*\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
(Make sure you can see Hidden Files)
Can you not just right click on Startup from the windows menu and click "open" or whatever it's called now? That should open the folder and then you can drag the shortcut in.
not sure what you mean mate.
anyone else?
Click on the Windows menu symbol (or press your windows key) go to "All Programs"
Locate the folder that says Startup and right click on it.
You'll get some menu options, one of which will be "Open" (may be labelled slightly differently under 7)
That will open the actual Startup folder so now you just place the shortcut you made into that folder.
