Rainmeter Desktop Customization Tool
15 Feb 2020
Q-Dance HQ
So this is a thread all about the Rainmeter Desktop Customization Tool. Anyone on OCUK that use it feel free to post your desktop layouts and even share your skins.
This is the skin i use for all the window/box for cpu, gpu etc: The processes skin (bottom middle) is by kaelri. However i cant find the skin anywhere. The top right system info is called sapphire. However, there is no author info for the skin.
Finally, this is the skin i am currently working on with confirmation from the author to mod the files to my liking entirely for hwinfo that will be universal at detecting your system info and doing all the work needed to auto change the .ini for your personal system. Simply install unload and it will detect your system and change all accordingly: https://www.deviantart.com/silverazide2/art/Gadgets-7-4-0-860144257
This skin has been modified a lot for my system. This only used msi afterburner before and i changed all the sensors to read hwinfo64 :eek:, then modified all the original layouts for each individual window (cpu and gpu etc.) Then made my own window for my pump by modifying the network window. As you can see the original hoxy 2 has very much been changed to look like hoxy 2 while being totally different.
Rainmeter's been an essential part of my setup for years. Brilliant program.
I'm currently using Gadgets 7.4.0 since I like the design but have made my own in the past.
Rainmeter truly is a great piece of software. been using it for at least the last 8 years now. Started using the animated steampunk version of hoxy 2 but the animated one had much higher cpu usage. It could be run without animation but then it had no colour or flare.
Have you got an image of your desktop layout?
oh i'd actually forgot all about rainmaker - used to have it installed until my last upgrade a couple of years ago when i did a clean install and never reinstalled it. will have to get it reinstalled and have a look at some new skins.
Sure, here's a shot of my left screen (I have 3 screens but Rainmeter only runs on this one)
All I've done is changed the colours to my preference.
I like it. Very simple yet informative.
