so the old rig went to my brother and he did a little upgrade and wants to push the 24/7 OC to a higher level.
spec:
3570k
ga-z77-d3h
8gb 2400 c10 ram
h100i
4.4ghz set by x44 turbo boost, high llc, vcore voltage response fast, pll 1.650v
all other setting standard or auto. vcore is showing as 1.248v in hardware monitor.
the temps are 22*c - 54*c
the dvid seems to be greyd out in the bios.
when the system was mine it had an air cooler and ran hotter than that. i wasn't able to run 4.5ghz without the odd crash from time to time. upping the voltage created too much heat.
as it ran stable with just a few settings changed i left it at that and didn't try to get it cooler or faster.
what would be the best way to start to up the speed, is it possible to keep using just the boost multiplier?
this really helps it clock down when on light duties.
thanks for reading
spec:
3570k
ga-z77-d3h
8gb 2400 c10 ram
h100i
thanks for reading
