- 22 Feb 2014
I have bought a new set of bath panels for our bath and unfortunately they are slightly taller than the ones we had so the bath need raising up (not easy to cut the new ones down)
Currently there is a trim that runs around our bath, I am not quite sure how easy it is to remove, does this go under the tiles ?
Can I safely remove this, raise the bath and then use some decent anti-mould silicone to form the seal ?
Or is this a bad idea ?
