Raising Door Frame Height Options
7 Apr 2004
Hi,
I'm looking at an old cottage at the moment that is all great except for 1 of the upstairs doors, which is made for hobbits. It's really short with a curved wooden beam over the frame going into the brick work.
Door frame sort of looks like this, and it's quite a thick beam: https://i.imgur.com/5flN0fH.png
Does anyone know how feasible it might be to be have the door height raised by 3-4 foot and what sort of costs might be incurred? Assuming it's an important load bearing wall etc.
@tntcoder those frames/arches are usually structural for the walls above and roof.
Raising them requires a fair bit of work and rsj support. This won't be cheap.
Is it a listed building as even internal works may require consent.
probably best to take a decent builder/architect around there to take a look.
sounds like it might be costly to change
that door is that size for a reason.
3-4ft is substantial! A builder should be able to do that for you. It will involve using "Strongboys" to prop the wall and floor/roof joists above, remove the timber beam, the wall above, then reinstall it (or a new modern lintel) higher.
There may be other structural implications, but impossible to say without knowing the bigger picture.
