RAM advice on XMP
26 Jan 2010
is the ram xmp compatible?
https://www.overclockers.co.uk/avex...mhz-quad-channel-kit-red-light-my-130-ar.html
also can some one recommend me some led memory, im looking at the above but its quite expensive, I like the led memory modules but the constant flashing is off putting, they all flash, i think the rog modules above is the only led memory modules that don not flash
Also should people consider xmp modules, is there really a performance increase?
