- 28 Oct 2002
I am currently in the process of building a new rig – my first in several years – and I thought it best to ask for some opinions on RAM options:
As RAM is relatively cheap, it seems superficially sensible to buy as much as you can of the fastest you can afford, but I suspect it is not quite so simple. It occurs to me that overclocking might be compromised by populating all available dimms and that tighter timings/faster speeds might be preferable to larger amounts of system RAM (beyond a certain point).
I plan to use the Asus Rampage IV board, which supports up to 8 dimms, permitting up to 64Gb (8x8Gb) of RAM.
Although it would be feasible to purchase enough high speed RAM (2400Mhz) to populate all 8 slots and max out the board, I wonder whether this would be wise. 64Gb seems unnecessary (even 32Gb might be excessive).
Firstly, would 8 high density dimms indeed compromise overclocking potential and/or RAM speeds enough to warrant either using only 4 dimms or 8 of a lower density/higher speed?
If so, which would be preferable – 4 x 8Gb or 8x4Gb?
Secondly , would you recommend Corsair’s Dominator series or Geil’s Evo Veloce?
Thanks for any replies.
