Ram Advice
20 Sep 2018
Hey,
I'd
really appreciate it if someone could give me an answer on this.
I currently have this in two slots
Ballistix Sport LT BLS2C16G4D240FSE/BLS2K16G4D240FSE 32GB Kit (16GB x 2) (DDR4, 2400 MT/s, PC4-19200, Dual Rank x8, DIMM, 288-Pin)
and I would like to buy these for the spare two slots so I have 64gb
Corsair CMK32GX4M2A2400C16 Vengeance LPX 32 GB (2 x 16 GB) DDR4 2400 MHz
would this be compatible or do I have to buy the exact same set of ram I currently have?
Thanks!
You don't have to buy the same RAM, although there's always a greater chance of it working and with less tweaking. Similarly, there's more guarantee that a matched kit of four sticks will work out of the box, than there is two separate pairs of the same RAM. Most the time you can get it to work, if needed swap slots, change some timings etc.
Nobody will be able to guarantee compatibility, only to give it a try. The frequency and timings on those kits are similar, there's a good chance.
Hey,
I'd
Thanks!
Hi,
Why don't you search the same memory Crucial Ballistix? Is there any particular reason you want different modules?
