RAM.. any real difference between brands?
Nope they're all very similar and usually use the same chips and PCBs.
I prefer OCZ as I've had no problems with RMAs with them previously but Corsair are excellent too.
Was looking at the OCZ, but noticed they take a little more voltage, and concluded that the Corsair might be better in my low airflow system.
Not that 0.3 volts is going to make any real world difference at all, but hey! :D
i have had the 2gb version of that kit in mine for the last 2 years with no problems what so ever, very good quality ram.
That kit has quite loose timings and probably won't OC very well...
On the other hand if you just want 4GB and aren't to bothered about mem bandwidth or OCing then its fine, think they come with corsairs lifetime warranty as well.
